01-25-2022, 06:03 AM | #1 |
Drives: ls3 Mustang Join Date: Feb 2015
Crank and new pistons to make a 454ci
SOLD !
Like new Standard/Standard Scat 4340- 4.125 stroke steel crank with 58 reluctor wheel.......With brand new 4.185 pistons to make a 454 Lsx....$1,350..... About the crank... 4340 Steel Crankshaft Chevy LS SuperStock Series 4.125'' Stroke for use with 6.125'' Rod 2.100" Rod Pin Diameter 6 bolt flange ..... SuperStock Series - 700HP+ & Forced Induction Applications Features: Shot Peened, Heat Treated, Precision Ground & Ion Nitride for Superior Strength Keyway Cut for Damper Throws Lightened Straight Shot & Chamfered Oil Holes Gun-Drilled Mains Lightening Holes in All Rod Journals Large Radius on All Journals Utilizes stock 11mm x 1.5 flywheel/flexplate bolts.... I have 2 Scat cranks and there both like new......one sold..... Also have excellent GM Ls3 dry sump crank........these are the better steel cranks.....$450 Info on the new pistons...... https://www.summitracing.com/parts/d...-4185#overview Last edited by booboo37; 01-30-2022 at 07:33 AM. |
