06-02-2022, 12:00 PM | #1 |
Drives: 2010 RS / SS Join Date: May 2021
Not another build thread, build thread
2010 2SS/RS
LS3 6spd 37k miles Replaced the LS3 yellows with BTR .660 duals. Adding the 78mm wind spinner this weekend. |
06-03-2022, 05:56 AM | #2 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Nice looking ride
Can't wait to follow this build thread. Be sure to post lots of pictures!
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
06-03-2022, 06:17 AM | #3 |
Great way to kick start the mods!
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
06-03-2022, 01:33 PM | #4 |
07-06-2022, 11:32 AM | #5 |
Per life, I haven't been able to spend nearly as much time working on the car as I'd like. But hot & cold side are on. Adding fueling is next. Then to work out the kinks.
07-08-2022, 07:58 AM | #6 |
Anthony S
Well that escalated quickly, looks good so far!
07-12-2022, 11:19 AM | #7 |
09-28-2022, 02:55 PM | #9 |
Drives: 2023/2SS/1LE/RadiantRed/A10 Join Date: Jul 2022
Don’t forget to take that front license plate bracket off before you put the front back on.
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
