06-07-2022, 07:34 PM | #1 |
Drives: 2010 SS Camaro Join Date: Jul 2018
Speaker Improvements for a Stock 2010 SS system?
Has anyone found decent speaker improvements for a stock 2010 BA system? I really don't want to replace the entire system. I would not mind replacing the speakers if it would help? The system just sounds flat... Any advice would be Great!
Thanks, Cory C
Husband and Father
06-07-2022, 11:04 PM | #2 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
the BA amp is junk IMO
06-08-2022, 02:19 AM | #3 |
where is that even located? from what I have seen the BA system is like 2 ohms or something?
Husband and Father
06-08-2022, 07:55 AM | #4 | |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: May 2017
I highly recommend taking the time to sound deaden your doors and rear deck as well as put stiff speaker mounts in if you decided to upgrade your speakers. It makes quite the difference on your listening experience. Feel free to contact me with any questions as I have done the entire stereo swap myself with the PAC kit. Sir, the amplifier is in the trunk just under the left tail light. You will see it when you pull back the carpeting.
StarSaber Mk. II
IG: StarSaber85(https://www.instagram.com/starsaber85/) Performance Mods: CAI, Inc. Cold Air Intake; ADM Racing Scoop; Bo White Ported Throttle Body; GPI Ported Rod Mod Intake; Kooks 1-7/8" Headers with Catted Connections; Solo Mach XL Axle-Back Exhaust Last edited by the85darkknight; 06-08-2022 at 08:02 AM. Reason: Incorporate answer to original question |
06-08-2022, 06:28 PM | #5 | |
Thank you for the Info - It really sounds Like more than I am wanting to get into. I would not mind upgrading the amp with the speakers especially if there was a plug and play adapter of some sort, but thats as far as I would be willing to go. I do not want to mess with the factory stereo! I guess I can go talk with my local Car Stereo shop and see if they have any experience or incite into this? I have looked into the PAC kits in the past - Just more than I wana deal with. Thank you all for your Input. I am going to contact my Local shop and see what he says about options. I guess a self powered sub would be an easy add to this system.
Husband and Father
