08-14-2022, 07:30 AM | #1 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
Mass Air Flow Sensor
Is this located after my air filter. But before the throttle body?
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
08-14-2022, 07:40 AM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Yes
08-14-2022, 07:42 AM | #3 |
Drives: 2013 ZL1 Join Date: Sep 2021
Yes held in by two screws right after the air filter.
08-14-2022, 07:49 AM | #4 |
How do you clean them?
OHIO |
08-14-2022, 07:50 AM | #5 |
Pull it out and use CRC Mass Airflow sensor cleaner-don't use carb cleaner.
08-14-2022, 08:50 AM | #6 |
Is it a good idea to spray them out routinely? With mass air flow cleaner
OHIO |
08-14-2022, 08:54 AM | #7 |
OK
OHIO |
08-14-2022, 08:55 AM | #8 |
How do you unplug the connector?
OHIO |
08-14-2022, 08:56 AM | #9 |
Or do you just undo the screws and clean in the engine compartment?
OHIO |
08-14-2022, 09:24 AM | #10 | |
Here, they are all the same, connection wise.
08-14-2022, 09:29 AM | #11 | |
And here..
08-14-2022, 10:08 AM | #12 |
The connector on my ZL1 is different from what is shown on this video, it has a grey connector on the bottom, after I lift it up I pull on the connector and it doesn't unlatch!
OHIO Last edited by 2013ZL1FUN; 08-14-2022 at 10:09 AM. Reason: spelling |
08-15-2022, 06:28 PM | #13 |
Well sir, I don't have a ZL1, but you can contact NOT A 45 on this forum, he is a Chevy tech and helps out a lot of folks on here. Great guy!!
08-16-2022, 07:21 AM | #14 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
Cleaning the MAF is something I rarely do. The only circumstance would be if I'm getting a higher gps reading then normal, and that sometimes can be caused by oil (from a over oiled filter), dirt, or even a small insect skewing the sensor. |
