09-06-2022, 08:33 AM | #1 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
ZL1 calipers vs. SS Calipers
Hey guys,
Currently, I have stock SS Calipers with R1 concepts drilled and slotted geomet coated rotors, and their optimum OEP pads which are a OEM quality material pad... Lately i have pushed the car pretty hard with some spirited driving and noticed that after a few pulls, the brakes can't seem to keep up, and start to squeal a bit, and they don't have the braking power that I want them to have. It feels as if I am using every ounce of braking power that the car has to come to a stop from high speeds. The pads and rotors are less than a year old, and both have ALOT of life left in them. I was thinking of switching to a set of ZL1 front calipers and rotors, but I am curious as to how much better they are in terms of performance? Is it possible that I just need to switch to a different braking pad for better performance? This car is 90% street driven, with 10% of hard driving, highway pulls, and some racing here and there. I want some advice before I drop about $1200 or more on a new front braking setup.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
09-06-2022, 02:36 PM | #2 |
Drives: 02 Camaro B4C Join Date: Nov 2016
A better pad will make an improvement. The ZL1 Big Brake upgrade will make a BIG difference. Larger rotors, more pad area and 6 pistons. Hard to go wrong.
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
09-22-2022, 02:42 PM | #3 |
Drives: 2014 Camaro SS 1LE Join Date: Oct 2019
The Raybestos ST43 are gamers.
Mostly track focused. VERY touchy and stop on a dime. BUT EXTREMELY noisy. I track 50% Weekend 40% Daily 10% I don’t mind people looking at me. Haha |
09-23-2022, 08:58 AM | #4 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
ZL1 brakes are a bargain and well worth it. Look at what aftermarket big brake kits cost. I have them on both my cars. If you really drive it hard, you can put in some brake ducting.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
09-23-2022, 03:29 PM | #5 |
For harder street use, a better pad would be a good starting point.
Hawk DTS60 or DTS70 are good options. I also had good luck with EBC Yellows. Raybestos ST43s are really good but, like Shu said, they are race pads and don't have "good street manners". If you step up to more track work, the ZL1 or Z06 6 piston conversion are almost mandatory. I run the Z06 calipers with the ZL1 2-piece rotors with DTS60s and titanium spacers. Couldn't be more happy.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
09-23-2022, 04:55 PM | #6 |
Drives: 2012 SS Join Date: Dec 2021
EBC yellow for me. work great.
2012 Camaro SS
09-26-2022, 06:08 AM | #7 |
Anthony S
I love my current setup so far, the R1 Concepts Geomet Rotors have been good to me, they don't rust, and don't make any loud noises. I also personally love the pads because they are virtually dustless, I rarely clean my wheels at all because there is never any brake dust. Performance wise they are great for everyday driving, but they don't like hard street driving. Recently after a few pulls and hard stops, they have been squealing at me when I come to a stop from what I imagine is too much heat. I think for now, I will add ZL1 front calipers and rotors to my list of things to be "on the lookout for" and see what happens. It looks like the CTSV Calipers are much more readily available, and slightly cheaper. Although they are basically all powdercoated yellow which I am not a fan of. We will see.
10-01-2022, 08:29 PM | #8 |
You can get the Vette calipers in red and black. Maybe more. And, they have vented pistons.
10-28-2022, 07:07 PM | #9 |
Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
So what kind of fluid are you using? motul has an excellent fluid for track use. But you would have to replace often, but it has a higher boiling point and controls mushy brakes.
10-30-2022, 06:03 PM | #10 |
I use Castrol. As far as how frequently you need to flush the fluid it doesn't matter what brand you use. All high performance brake fluids require frequent changes.
