Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Miscellaneous Items
Old 09-22-2022, 11:39 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
2010-2015 CAMARO SS BASSANI EXHAUST
https://www.southerncarparts.com/201...st-p-3890.html
Designed and manufactured specially for the 6.2L Camaro SS, this Bassani exhaust is the product of extensive exhaust R&D. If you're looking to improve exhaust tone and volume, while also increasing HP and Torque numbers across the RPM band, then an aftermarket exhaust is perfect for you. This axle-back exhaust will provide impressive gains across up the RPM range and couple those performance numbers with a powerful exhaust crescendo. Manufactured using the highest quality stainless steel materials, you can also rest assured that this exhaust is as durable and stylish as it is impressive.
Available both with stylish, rolled, stainless steel exhaust tips, and without for use with the GM GFX package. This system couples perfectly with a Bassani X-Pipe to make a complete cat-back exhaust for your Camaro SS, as well. By adding a Bassani X-Pipe, you'll increase exhaust flow even more beyond the restrictive stock system. More exhaust flow equates to more exhaust tone, volume, and performance. X-Pipes also even out exhaust tone and help reduce decel pop gurgle when letting off of the gas.
Please select your exhaust options from the drop-down menus.
APPLICATION: 2010, 2011, 2012, 2013, 2014, 2015 CAMARO
southerncarparts is offline   Reply With Quote
