Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros > 3rd Gen Marketplace
Old 09-23-2022, 01:58 PM   #1
SpartanB482
Drives: 2011 Camaro SS LS3
1986 Z28 Bracket ROLLER
I'm selling my 86 Camaro bracket car, its time to go big tire and I dont have the time and tools to cut this one up. It will make a great starter car for bracket racing.
*New Lakewood 90/10 drag struts, just bought this year
*Jegs 15x4 front wheels, MT 26x4-15 front runners.
15x10 Weld Draglite rear wheels, 28x10.5-15 MT ET Drag slicks with plenty of life left
*6in fiberglass cowl hood w/ hood pins
*Disc brakes front/rear, line lock front/rear. REAR LINE LOCK IS NOT HOOKED UP
*S10 manual gearbox w/ Ed Quay steering damper
*Front mounted 3gal fuel cell
*Electric cooling fan
* 8 point rollbar, weld in subframe connectors
*Mallory Hyfire VI ignition box
*Batteries have been relocated to rear of car, has exterior posts and battery kill switch
* 12 bolt GM Moser Housing w/ 35 spline Moser axles. Has 4.56 pro gears w/spool
*Ladder Bar suspension, single adjustable coil over shocks
I also have a set of 15x8 wheels to match the fronts with a set of 275/60/15 Pro Bracket Radials that can be bought for extra.
Fuel pump/filter, shifter, and delay box are not for sale and will be removed with engine and trans at time of sale.
Located in Hardinsburg, KY 40143
$10,500 obo. Local pickup only, will meet within a reasonable distance if necessary.
SpartanB482 is offline   Reply With Quote
