Old 07-01-2023, 01:01 PM   #1
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Wiring guru
Hey guy, I just installed a holley prodash in my 2010 camaro. I need some help finding what wires to tap into in order to get the signal for turn signals, high beam indicator, and fuel level sensor.
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 07-01-2023, 03:29 PM   #2
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Let me know if these help.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
acutron42 is offline   Reply With Quote
Old 07-02-2023, 10:54 AM   #3
BigMatt
BigMatt's Avatar
thank you! I'll try to trace those
Old 07-02-2023, 04:53 PM   #4
acutron42
acutron42's Avatar
No problem! If you need anything else let me know or send me a pm. The turn signals come out of the bcm.
Old 07-06-2023, 08:56 PM   #5
BigMatt
BigMatt's Avatar
Got it all figured out. https://youtu.be/nSkJsk85-2w
Old 07-06-2023, 09:41 PM   #6
acutron42
acutron42's Avatar
Sweet! It is always good to see these things get sorted out.
Old 07-07-2023, 02:02 PM   #7
BigMatt
BigMatt's Avatar
here's how I wired it all up https://youtu.be/kSCdASd3seA
