07-05-2023, 10:44 AM | #1 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
ATI balancer question
Does this look right? Inner pulley is the ac pulley, secondary pulley is the serpentine drive and the billet pulley is the supercharger pulley. It's a little strange because the kit came with 12 bolts. 6 hold the serpentine pulley to the hub. And it looks like 3 bolts go between the supercharger pulley to the rear ac pulley. So... you would bolt the 2 ATI pullies together for install purposes, then remove the 3 bolts, and reinstall the 3 longer bolts to attach the front and rear pullies together? Hopefully the way I explained it makes sense.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
07-05-2023, 06:42 PM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I don't have any great pictures but that doesn't look right.
07-05-2023, 08:29 PM | #3 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Mines different from that. I think pulley placement also depends of what type and brand of supercharger you have.
My supercharger had specific instructions on where the pulleys went. Did you check with the supercharger mfg? Also ATI are good people. I've called them a couple times and they were very helpful.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
07-06-2023, 11:10 AM | #4 |
The three longer bolts probably go through all three pulleys and into the damper hub itself. Did they (ATI) not send installation instructions? Perhaps they have them available for download on their website?
Are you running an LSA blower or Centri setup? -Scott |
07-06-2023, 11:27 AM | #5 |
Anthony S
That looks about right then. You are also using 3 bolts to attach the ac pulley. I think I have this right then.
