07-14-2023, 10:38 PM | #1 |
Drives: '12 2SS 6MT Join Date: Mar 2023
Changed diff oil, tires chirping now?
So I replaced the diff oil with Royal Purple (that already has additive in it) and drove it to a parking lot and did some figure 8s. No weird sounds or clunks, but then as I was making a turn out of the lot the tire chirped as I was slowly pulling away, almost like the sound a welded diff makes (mine did it only once though). Should I be worried about adding friction modifier or continue to drive with it? Less slip in the diff isn't necessarily a bad thing to me as I will be autocrossing but if there's potential for damaging the rear end I'd like to avoid that. Any input would be appreciated.
TLDR: changed diff oil and tire chirped making a 90 degree turn but not during figure 8s, does it need friction modifier?
Cold Air Inductions intake w/ race scoop, Borla ATAK Catback, EBC Yellows & RBF 600, BMR strut brace, Z28 replicas, Factory Hurst Shifter
07-15-2023, 04:05 AM | #2 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
Try this.
07-15-2023, 06:54 AM | #3 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
You don't want to over do the Friction modifier, I would run it for a few days and see how it is doing.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
07-15-2023, 10:37 AM | #4 |
Sounds like a solid idea, only problem is I have autocross tomorrow
07-15-2023, 01:24 PM | #5 |
If you were to add the additive I'd add like half the recommended amount since yours already has it in it. When I was running Amsoil I didn't need to add any, now I run a True Trac.
