09-09-2023, 11:04 AM | #1 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
FEELER: CUSTOM CRASH BAR
Hey Team,
As discussed in another thread, I was interested in a custom crash bar solution that didn't block airflow, allowed for better aesthetics with perhaps better low speed impact security based on the addition of a lower bar. This solution would have provisions for the tow hook, and brackets for the brake ducting. Clearly there is no current solution, and I'd like to figure this out... Question; when finished with mine, would any of you be interested in purchasing one? If I can get enough pre-orders, we will have better buying power for the fabricator. Everything would be fabricated from steel, and would ship raw finish, so you can powder coat, or paint to the color of your choice. Thoughts? Any mass interest?
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi |
09-09-2023, 11:36 AM | #2 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Let's see the final product, then I think you will be able to determine true interest. I'm intrigued though.
09-09-2023, 01:15 PM | #3 |
Petro-sexual
+2
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
09-09-2023, 03:23 PM | #4 |
Drives: ‘23 ZL1-1LE Join Date: Mar 2023
So you’re looking to create a CHP push bar type steel bumper? Maybe I need to read the other thread….
09-09-2023, 05:04 PM | #5 |
Drives: 2021 Camaro ZL1 Join Date: Mar 2023
Definitely interested depending on final product and price.
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, Atturo 315 AZ850DR |
09-10-2023, 06:37 AM | #6 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
I am not an engineer but, if GM could have done something different they would have. Of course they had to comply with federal crash tests. I think insurance companies might not pay damages in an accident if this front bar got removed or modified. Still would like to see if there is an alternative.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
09-10-2023, 07:57 AM | #7 | |
I agree, the bar I have in mind, may not fare as well as the stock bar, but that is not the reason for this upgrade and nor was it for the others who have designed a similar, but lacking alternate solution. I'm just trying to take it one step further and move the bars out of the way completely, add provisions for the tow hook, and air ducking... I'll be sure to post photos once done... stay tuned, and thanks for the interest!
09-10-2023, 08:34 AM | #8 | |
Drives: 2021 ZL1 1LE with PDR Join Date: Oct 2022
Or not making the damn side skirt one part with a painted rocker. Or making the clips for the carnards better Or using a better hood wrap Yeah, i could think of a few. |
09-10-2023, 08:59 AM | #9 |
Waiting 4 A Point By!
Drives: 2020 ZLE, C8 Z06-Z07 2LT Carbon Join Date: Mar 2023
I have no idea why they call it a "Crash Bar" as every ZL1 I have seen in a front-end crash, that huge cooling encumbrance did absolutely diddly-squat!!!
I plan on removing mine and making a mount for the air-oil cooler, removing the joke of a engine coolant to plate heat exchanger mounted on the side of the block.
09-10-2023, 09:47 AM | #10 |
Ok, now I get it. You’re removing an existing internal structure, sorry I envisioned some clunky exterior piece, lol! Since I really haven’t studied the part, my question would be, does that piece actually provide structural integrity to the chassis as well as providing some kind of integrated crash crumple design. I don’t think that the term crash bar necessarily means it’s designed to mitigate damage to the car, it’s likely a part designed to ensure what ever destruction takes place saves the occupants.
09-10-2023, 02:57 PM | #11 | |
Drives: 24 Sliverado 1500 ZR2, 2017 ZL1 Join Date: Feb 2021
Finally on the way to 1K.....
09-10-2023, 03:06 PM | #12 | |
Drives: 2022 Rapid Blue ZL1 Join Date: Feb 2022
2022 M6 Rapid Blue ZL1
Performance: Kong X-Port OEM blower, 1 7/8" TSP headers (Polydyn coated), Corsa Intake/X-pipe/NPP Exhaust, LT5 95MM TB, DSX FlexFuel sensor, Dedicated Motorsports inline fuel filter / fender tank, Katech Dual fuel pump, WeaponX Boost freeze chiller, WeaponX center and aux HX, PWR oil cooler, Elite E-2X catch can, and Griffin Motorsports front crash bar. Tuned by Pat G 731 WHP on a Mustang Dyno. Suspension/Brakes: Eibach lowering springs, Vorshlag camber plates, Full SPL rear control arms, DSC Sport suspension controller, Blackwing F/R brake cooling ducts. |
09-12-2023, 11:06 AM | #13 |
I think that was my point, maybe I didn’t get that across. It’s not designed to save the car. Though it may also be providing structural integrity to the chassis as well.
09-13-2023, 07:09 AM | #14 |
Here is a picture of the part in question. Anyone have pic of it removed?
