10-03-2023, 09:01 AM | #1 |
New Product - Carrier Bearing
**I have no affiliation with this company nor have tried out the product*** But it looks interesting for sure.
Here is a link to a company that has developed what looks to be a better carrier bearing support for the 5th gen 2pc driveshafts. There is a street & track version available. Pre-order is $249 and normal price looks to be $299 https://www.jxbperformance.com/produ...7vao3V1oHBX8tY
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
10-03-2023, 11:42 AM | #2 |
Oh boy, that looks promising! Watching the ZL1 underside vid, I had no idea they moved around that much. Kind of how the cradle mounts do as well, which is why a lot of guys went solid. I still have my stock DS and all the hardware for it sitting in my parts room. If I ever need it again. I saved that link you posted. Thanks for the info Ashen.
10-03-2023, 04:54 PM | #3 | |
10-03-2023, 05:04 PM | #4 |
It don’t come easy.
When ordering, it asks for bushing stiffness, prefered. Soft= street - Hard= track and final selection is “give me both”. I would guess that the latter option is somewhere in between the soft and hard?
10-03-2023, 05:15 PM | #5 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Price goes up on the “give me both” so I would say they send one of each. The bushings look split so probably easy to change.
10-03-2023, 06:13 PM | #6 |
Yep. And the fact that there is a website I saved also that someone posted on here for the rubber couplers, we should be golden if we ever want to rebuild our "stockers"!!
10-03-2023, 06:54 PM | #7 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Yeah I have been watching this on Facebook, I think I am going to order one and if my new one piece isn't smooth I'll go this route.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
10-04-2023, 03:50 AM | #8 |
It don’t come easy.
Ah. Didn’t even check price difference. Makes sense.
10-04-2023, 10:28 AM | #9 |
That's why I saved my stock DS, in case I do have any issues with my 1 pc in the future.
10-04-2023, 07:07 PM | #10 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
Looks like a very nice product ! Thx for posting this !
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
10-08-2023, 12:34 PM | #11 |
And here is the links for the rubber guibo's, just in case you missed them.
https://www.driveshaftparts.com/inde...roduct_id=4516
10-08-2023, 01:10 PM | #12 |
The carrier bearing is on back order for the Ac Delco ones and not available for the GM ones, Whats ones are you guys using when you replace yours?
10-10-2023, 11:44 AM | #13 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
This looks like a good upgrade judging by the comparison video there is a lot of slop, wonder if this is why 5th gens break so many axle shafts lol. I’m gonna preorder the stiffest they got as nvh doesn’t bother me too much lol my interior is basically stripped.
427 Dart block, M311 Heads, Pat G Custom Cam, ATI Balancer, BO White Stage 3 TB, Custom CAI, FI Tech Sheet Metal Manifold
10-11-2023, 08:58 AM | #14 |
Ordered with both bushings, Now I need to order a new bearing, Not sure if I can get just the bearing. I may or may not use it but figured I could always re sell, Going to see how the new one piece works out first.
