10-22-2023, 03:35 PM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2023
Bilstein B16 (PSS10)
Anyone have or used the Bilstein B16 colorer kit. I am interested in getting this kit, but have not really seen any info on this kit. Everyone seems to be running Pedders or something else.
DSE 1.5 is too low for me. Bilstein 1.25 may be passable. Ohlins .8-1.0 perfect drop. |
10-23-2023, 02:59 AM | #2 |
Drives: 2011 SS Join Date: Jul 2023
Yes, but under an E46 BMW. Nothing but praise for the ride vs. how stiff it is, it's much better than previous coilovers I had. The hight is adjustable.
10-23-2023, 05:20 AM | #3 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I have the B16 struts and like them, I can only assume that the coilovers are better and will likely be my next step when these wear out.
