11-26-2023, 09:05 PM | #1 |
Drives: 2022 Camaro 1ss 1le Join Date: Jan 2022
60-130 ss times?
Wondering what’s your guys 60-130 ss times? I keep getting 10.2-10.5 times. I’m fbo with btr stage 1 cam. Not done with the remote tune just needs e85 run but with 91 I’m getting those times. Do those times look reasonable for 91? Or is my car a dud lol. Gpi is remote tuning my car at the moment
11-27-2023, 07:12 AM | #2 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Auto or manual trans?
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
11-27-2023, 07:49 AM | #3 |
Drives: 98 Camaro Join Date: Apr 2022
Probably gonna be much quicker with e85. You are at higher elevation so there’s probably a half a second or more there
11-27-2023, 10:17 AM | #4 |
A10 speed. Well I hope so, we’ll see once it’s all done
11-27-2023, 06:41 PM | #5 |
Drives: like an old lady Join Date: Jun 2012
i think i saw your post on fb.
there is something going on with your car. if they are still in the process of tuning it, id wait until it is "done" before making any comparisons. imho that car should easily be in 7s on ethanol. for comparison sake now, my 18 ss 1LE went 9.7x with a ported LT1 manifold, full exhaust & ethanol. that was a m6 car with a raceweight well over 3900 lb.
2016+ camaro: everyone’s first car
11-27-2023, 09:37 PM | #6 |
Well it better be or else I’ll be switching tuners lol jk. I’ll wait till It’s all done and wait until I go to la where I’ll be getting a better da and see what I get there with e85
11-27-2023, 10:51 PM | #7 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
I would assume that is OK for your setup but still need some tweaking. I assume you should faster due to you being a A10. It looks we have the same setup just different cam but cam specs are similar. I also have the LT2 IM w/ Ported Stock TB (will upgrade soon to MSD/103). The only reason I say that is because I did those numbers in AZ heat with 3500+ DA and 2000+ elevation (10.2-10.3) on 91. Idk what your tire setup was on your runs, but this is my 60-130 with stock ss 1le tires with a rear seat delete with E60 at the time. I am still trying to improve on it though since I just added a drag pack but I am waiting for the weather to drop down and find better elevation. I'm learning in AZ the heat and elevation is a huge factor on NA cars and that's why I see so many boost applications out here vs what my hometown usually run. I cant wait to see what you run once everything is fine tuned.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
11-29-2023, 12:40 AM | #8 |
2Spdsy
Drives: 2021 Camaro LT1 A10 Join Date: Mar 2016
