12-28-2023, 05:51 PM | #1 |
Drives: 2012 Camaro 2SS Join Date: Jun 2023
Brake Rotors, help me decide.
Doing a full brake replacement/upgrade, bought the car in June and know nothing about the brakes except they aren't up to their potential.
Brake rotors is where I'm kind of stuck. I've narrowed it down to a few choices so far. 1) Detroit Axle drilled and slotted, cheapest I'd feel comfortable paying, just not sure about their quality. 2) Raybestos 300 "S-Grooved". I trust the Raybestos name to deliver a quality product. 3) Baer Sport Series drilled and slotted. These cost a bit more than both options above, but don't mind paying it if there's a tangible gain. Baer obviously is a recognized name in brakes for a reason. 4) R1 eLine drilled and slotted. About the same price-point as the Baer Sport series, not sure if there' much difference in quality either way? 5) Hawk, another step up in price, wondering if the added money brings any more to the table for my use? Opinions or experiences with these choices? Any options I'm overlooking? Will be going back with Brembo low-metallic pads, Motul 5.1 fluid, and thinking Powerstop SS Braided lines. Thanks. |
12-28-2023, 05:59 PM | #2 |
Drives: 2013 ZL1 Join Date: Nov 2018
Brake fluid and the pads are what make brakes effective, not rotors.
Flush the system with DOT4 fluid, put on a NAPA Premium or AC Delco rotor and the stock Brembo pads for exceptional street brakes. If you want jaw dropping brakes put on Carbotech AX6 pads. Whatever pads you use make damn sure you bed in the pads.
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
12-28-2023, 06:26 PM | #3 |
One of my Camaro friends has the R1 Concepts drilled and slotted rotors, he likes them. Personally for me, I like my OEM AC Delco rotors better. Nice and shiney looking after you drive the car. Don't need to spend all that extra money to stop well, unless you're tracking the car or you're just going for the "look" of the drilled and slotted. Nothing beats the Brembo pads and stock rotors.
12-28-2023, 06:59 PM | #4 |
Drives: 2013 Chevy Camaro 1LT Join Date: May 2022
I installed the Detroit drilled and slotted one last month. Good quality and great stopping power. They look pretty good too.
12-28-2023, 07:49 PM | #5 | |
Drives: Camaro 2SS Gen 5 Join Date: Oct 2023
In contrast..... the Camaro's brake system is all Michigan-based. The Brembo rotors and Brembo brake pads are assembled in Brembo's Homer, Michigan, plant. Last edited by AlisoBob; 12-28-2023 at 08:04 PM. |
12-29-2023, 10:55 AM | #6 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
If you are going to spend extra money, spend it on upgrading to the ZL1 brakes using the Vette Z06 calipers. Otherwise, OEM replacement units work well.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
12-29-2023, 11:10 AM | #7 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Like tires and engine oil you're going to get a lot of different opinions. I'm a big fan of USA made Carbotech. I have the XP10s on my track C5 Z06 and they work great. The intended use of the car will determine the pad compound you should purchase. Do yourself a favor and check out thier website and then talk to the good folks at KNS. Great customer service. They talked me OUT of overspending on my brake system.
12-29-2023, 12:46 PM | #8 | |
They are a big help keeping heat off the calipers. What they stock there are serious brake rotor/caliper brands. No cheapo "style" brands. Now, let me back up by saying: Suggestions on Brake rotors/pads (same as wheels/tires) are going to vary A LOT depending on who is chiming in. Some of us here do road course track days, so our suggestions on rotors and pads are going to be way deferent then those who mainly drag race, from those who cruse/do shows, and from those who just daily drive. With that being said, my rule of thumb is: If it is an essential item for the performance/safety of the car, do not cheap out. Tires, brake rotors/pads, oil/oil filters fall under this. The amount of people who cheap out on tires and brakes terrify me. The factory rotors and calipers are Brembo and are very good for 98% of use cases. Definitely change the brake fluid to a DOT4 grade fluid. The factory fluid is not up to being pushed hard. Braided lines are always a good idea. Goodrich braided lines are great and are what I run. Powerstop lines are a good alternative. Pad wise, I run currently run Hawk DTS70s in the front and DTS60s in the rear. But I do road course track days and am running the Z06 front brake conversion. They dust a lot and squeal like hell when they are cold, but they can stop my Camaro all day long from 150mph+. I had Raybestos ST43s on before and they were great as well. Carbotech is also a great brand, I just have not tried them yet. EBS is a good brand I have used in the past as well with good luck. Like mentioned earlier, the factory Brembo rotors are great. I run the factory ZL1 2-piece front Brembos on mine. ZERO complaints for 3 years now. My rears are also the OEM Brembos. You can get more "aggressive" styles with slotting from Brembo/DBA/EBS/Raybestos/GiroDisc as well if that is the look you want.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
