Old 02-09-2024, 09:52 PM   #1
FunnyRS
Drives: 2011 Camaro 2LT RS, 42,000mi
Question Shaking at specific speeds and burning smell
Hello all,
My 2011 LT RS has lately been shaking a bit while I'm driving. It gets so strong the steering wheel also shakes in the 35-50mph and 65-80mph ranges. The specific speed that I feel the shaking the most changes within those ranges every day. Also, before I noticed the shaking, I noticed an occasional very strong burning smell that seems to come and go whenever it wants and I can't identify where it's coming from.
Sent to Firestone for wheel alignment, rotation, and balancing. Sent to another shop who said all they saw was cupped tires and a botched alignment job. Shaking and burning smell persists.
List of symptoms:
-Shaking, strongest at random speeds between 35-50mph and 65-80mph in all gears.
-Occasionally a very strong burning smell.
-Faint, brief squealing sound under hard acceleration between gears 1-3.
Any ideas?
Thanks!
FunnyRS is offline   Reply With Quote
Old 02-10-2024, 05:55 AM   #2
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Shaking can be drive shaft or CV axle.
Cupped tires ?
Can be tire frame failure,how old are tires ?
Old 02-10-2024, 06:04 AM   #3
bsn
Drives: 2013 ZL1
Cupped tires will absolutely cause shaking, usually a sign of worn out struts or tires way out of balance. If your alignments is bad enough you can scrub the tires and smell burning rubber-should be obvious looking at the tire wear. Have you hit a curb or pothole recently. I would suspect bent or worn suspension-a shop should have refused to attempt to align the car without replacing the tires and finding the damaged part. I would deem the car unsafe to drive anywhere but to a repair shop until its fixed.
bsn is offline   Reply With Quote
Old 02-10-2024, 06:57 PM   #4
FunnyRS
Not sure how old the tires are, got the car 6 months ago with them already on it and they're definitely not originals.
Old 02-10-2024, 07:03 PM   #5
FunnyRS
I did nudge a snowbank recently, which was immediately before the shaking started. I had that in mind when I went for the alignment. Going back to Firestone on Monday to take advantage of the alignment warranty, and I will also ask them to check the suspension. Thanks!
Old 03-07-2024, 11:10 AM   #6
RACERJOE1
RACERJOE1's Avatar
Drives: 2014 2SS
If you haven't already found the problem, I would have the brakes checked, the symptoms you describe sound exactly like stuck brake caliper/piston.
RACERJOE1 is offline   Reply With Quote
Old 03-07-2024, 02:47 PM   #7
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Went through this with another vehicle some years back. Look at the rotors and see if bluing is occurring.
0stones0 is online now   Reply With Quote
Old 03-08-2024, 06:30 PM   #8
hesster
hesster's Avatar
Drives: '10 C5 SS, '77 Bandit T/A
Steering Wheel shaking indicates a imbalance condition in the drivetrain. Most likely Tire/Wheel Imbalance (lost a wheel weight?), warped Rotors, or alignment way out of spec.
Key input is you 'nudged a snowbank". So you nudged your suspension, T/W, or Alignment enough to start the vibration .
hesster is offline   Reply With Quote
Old 03-08-2024, 09:09 PM   #9
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
Could have ice in the barrel of the wheel.
chef-beavis is offline   Reply With Quote
burning, shaking, smell, vibration
