Old 02-27-2024, 05:34 AM   #1
PhantomBlack
Drives: 2014 Camaro 2SS
2014 Camaro 2SS A6
Hello all,
I'm seriously contemplating on selling my Camaro. All of the engine and diff work was done in house at Gwatney Performance Innovation (GPI). I have the receipts to verify the work done.
My car made 420 WHP on their dyno and had 90K miles on it when they did the work. Some time later I had a local shop CHenry Motorsports add the ZL1 supercharger. I have receipts for work done here as well.
The car was street tuned at this shop, no dyno numbers. But tuner predicts it's in the high 500 to low 600WHP. I'm the 3rd owner, car has never been in an accident, clean title, paid off.
The car sits at 101,xxx miles. It has some paint chips on the front bumper and drivers door has a few dings in it. Since I've owned it (8 years now), it's always been garage kept.
I'm asking 17K OBO.
Here is a break down on the build:
ENGINE:
Camshaft: GPI - L99 SS1 VVT
Valve Springs: Brian Tooley Racing - .660" Lift Platinum Valve Spring Kit
Pushrods: GPI - 5/16" Hardened Pushrods
Lifters: Chevrolet Performance - Set of 16 OEM
GPI - LS3 Micro-Polished Rocker Arm with Bronze Bushing Upgrade
Chevrolet Performance - High Volume LS Oil Pump
Mishimoto 169 Thermostat
Texas Speed 1 7/8 Long Tubes w/HF cats
NGK TR7lX spark plugs
Mighty Mouse (wild) Catch can
JLT ZL1 Air intake
Phastek Performance Air intake scoop
SUPERCHARGER:
LSA supercharger conversion
ZL1 Coolant pump
ZL1 reinforced brick
Lingenfelter Solid Isolator
2.50 Upper Grip Tech pulley
Ron Davis Heat Exchanger
Pro Speed Coolant Reservoir
FUEL:
ZL1 fuel pump
ADM FPCM
DW 65lb (700cc) injectors
TRANSMISSION:
B&M Transmission pan
JRE Transmission Dipstick
DIFFERENTIAL:
Eaton TruTrac Differential
GM Performance - 3.91 Gear Set
EXHAUST:
NPP cat-back with functional valve/noise flaps
EXTERIOR:
Gen5diy RS headlight & taillight conversion harness
OEM RS headlights
Phastek aftermarket 6gen taillights
OEM 1LE front splitter
Z28 grill and Flow tie
Aftermarket Z28 style rear spoiler and rear diffuser
NOTE:
This car needs the A/C system serviced. Air is blowing warm and it's not a blend door problem, I checked.
I can send more pics to serious buyers.
Mods: GPI SS1 VVT cam, TSP long tube headers, LSA conversion, ZL1 fuel pump, ADM FPCM, DW 700cc injectors, Lingenfelter solid isolator, Dedicated Motorsports ZL1 reinforced brick, ADM Griptech 2.5 pulley, JLT CAI, Phastek intake scoop, NPP cat-back, GM 3.91 gears, Eaton Truetrac, Tuned by Chris @ CHenry Motorsports.
PhantomBlack is offline   Reply With Quote
Old 03-05-2024, 12:23 PM   #2
hemiller3
Drives: slow zl1
pm sent
hemiller3 is offline   Reply With Quote
Old 03-09-2024, 07:37 AM   #3
mediapirate
Drives: 2013 Corvette Grandsport
PM sent as well haven't heard back though.
mediapirate is offline   Reply With Quote
Old 03-09-2024, 07:42 AM   #4
PhantomBlack
Sale is pending.
