Old 03-21-2024, 07:29 PM   #1
Ckmerc
Drives: 2013 zl1
Upgrade Throttle body or not?
So I am going to do my second set of mod upgrades [2013 zl1) and my buddy mentioned adding Throttle body upgrade (Nick Williams 102 is what my mech has in stock).
Question is…will I notice that much of a difference for the cost? ($700 installed)
Background
Once this next round is done…I will have had done the following
- ported blower, upgraded pulleys, E85 upgrade, new injectors, cam, long run headers, new clutch, 2 tunes…should end up at approx 800rwhp
Thanks for advice in advance!
Ckmerc is offline   Reply With Quote
Old 03-21-2024, 08:15 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
At that power level you should notice a difference. I picked up something like 40 whp going from a ported 90 to a 103 for my Whipple.
Sent from my Pixel 8 Pro using Tapatalk
Old 03-22-2024, 11:59 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Hey Larry, lol, I just saw this and was going to mention you and what you did gain from the 102 I sold you!! Awesome brother!!
Old 03-23-2024, 05:53 PM   #4
Ckmerc
Drives: 2013 zl1
Whoa. Ya. That is noticeable…. Thanks!
