03-10-2010, 01:31 PM | #1 |
Drives: 2010 IOM CAMARO Join Date: Jul 2009
Need vin help where can i go to decode a 69 vin
A customer of mine bought a 1969 and beleaves that it is a 302 cid z28 car can anyone help?
03-10-2010, 04:07 PM | #2 |
Drives: 1999 Camaro Z28, 1969 Camaro RS Join Date: Nov 2009
there isn't anything in the VIN that denotes a z28. there may be some marking on the trim tag ("X" code .... i'd have to look it up in a book). but not all z28's would be marked. unfortunately, there are more clones on the roads these day .... more "1969 z28's" on the road than were produced in 1969, so it's really important to do all of the checking prior to paying any cash!!!
all 1969 z28's came with front disc brakes, manual trans, 302 DZ code motor ("DZ" stamped on the block, passenger side front of motor behind alt) and no A/C. no z28 convertibles were produced. there may be a build sheet behind/under the rear seat and/or between the trunk floor and the gas tank. let us know what you find out .... it will be interesting to know if it's real or not. you might consider looking for info on camaros.net .... it's a forum focused on the early camaros. Last edited by billscamaros; 03-10-2010 at 04:09 PM. Reason: additional comment |
03-10-2010, 04:46 PM | #3 |
Go to Nasty Z28.com. You will probably find someone who can help you decode the VIN there for you.
03-10-2010, 08:27 PM | #4 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Was power steerig an option on 69 Z28's? I remember power assist brakes and manual steering.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
03-11-2010, 08:29 PM | #5 |
yes ..... you could get a '69 z28 with power steering.
orangetwk - there were approx. 20,300 camaros equipped with the RPO code z28 produced in 1969. the VIN itself is pretty straightforward. For a Camaro, it should be: example: 124379N111111 where 12 indicates chevrolet camaro, the even number 3rd digit indicates a V8 (odd number indicates inline 6), 37 indicates a coupe, the 9 indicates production year, the N indicates the plant where the car was produced (N- Norwood OH, or L for Van Nuys, CA), and the final six digits are the sequential production number. |
03-11-2010, 09:07 PM | #6 |
Drives: 2010 Camaro 2SS/RS M6 BLK/BLK, Join Date: Nov 2009
Artful Dodger 2010 Camaro 2SS/RS M6 BLK - 2015 Maserati Ghibli Q4 BLK (dd) - 2004 MB C240 BLK (wife's) - 1996 BMW 328i BLK
03-11-2010, 10:10 PM | #7 |
Here is another good resource...
http://www.camaros.org/numbers.shtml This will help you to decode the cowl tag. Good luck!
03-12-2010, 02:00 AM | #8 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
the VIN will not decode the Z/28 part but it can tell you some things.
124379NXXXXXX = "1" is for Chevrolet, "2" is for Camaro series, "4" is for V8, "37" is for coupe, "9" is for 1969, "N" would be for Norwood OH plant but you might find "L" for Los Angeles CA. The X's are going to be numbers that identify the car in sequence for that production plant. The numbers start with 500001 for the first car built at that plant and go up from there. Figuring out if a car is an original Z/28 takes a lot of looking and even then, without the original "born with" engine, it will be very difficult to say for certain that it is an original Z/28. There are various other things it needs to have, so you look for those things. You can usually find other clues that will rule it out from being a real Z/28 pretty easily when you know what to look for. Bottom line - most fakes can be identified but being absolutely positive on a real one is a challenge without strong documentation. -Mark. |
03-12-2010, 06:38 AM | #9 |
Thank you all for your help. This site is great!
03-12-2010, 08:37 AM | #10 | |
Drives: GMC Acadia, Chevrolet Camaro Join Date: Jan 2009
The only options you could not get on a 1st generation Z were automatic transmission and air conditioning.
2024 Camaro 2SS
03-12-2010, 08:28 PM | #11 |
03-20-2010, 10:51 AM | #12 |
The Autoglass Guy
Drives: 1969 SS 396, 1969 SS , 2010 RS Join Date: May 2009
this site is great to.
http://www.chevy-camaro.com/faq/chev...o-faq-Z28.shtm |
Similar Threads | ||||
Vin Number Location Thread. | Dboy23 | 5th Gen Camaro SS LS LT General Discussions | 58 | 12-27-2009 08:40 AM |
VIN 30,000 | PAUL SS | Camaro Price | Ordering | Tracking | Dealers Discussions | 43 | 08-01-2009 07:49 PM |
SS VIN range that have faulty transmissions? | Supermans | 5th Gen Camaro SS LS LT General Discussions | 35 | 07-29-2009 02:04 PM |
R6P, VIN and spare tire question. | CyberDude | 5th Gen Camaro SS LS LT General Discussions | 10 | 07-06-2009 05:16 PM |
