Old 03-18-2010, 04:40 PM   #1
spectrepig
Drives: 2010 2SS/RS. Black w/ inferno orang
intake and(?) computer upgrade
I am hearing a few different points of view on this and looking for some advice. I have a 2SS, and looking at all the intakes. Some people are telling me the computer will compensate for the higher airflow, and others tell me that you need to re-program the computer in order to get the true gains of the set up. Any thoughts, from ya'll? Thanks.
spectrepig is offline   Reply With Quote
Old 03-18-2010, 04:43 PM   #2
victoryred1ss
victoryred1ss's Avatar
Drives: 2010 SS M6 2016 2SS A8
Both are correct, you will get gains from just the cold air kit but you will get more if you tune it also.
victoryred1ss is offline   Reply With Quote
Old 03-18-2010, 05:11 PM   #3
spectrepig
So the computer will compensate and you will see some more HP and it will not have any negative effects??
Old 03-18-2010, 05:21 PM   #4
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
You should not get negative effects if you buy the proper system...some companies are selling systems where you need to re-program the car, such as Vara-ram.
If you buy the other versions which do nto require a tune, you will have the benefits that the system advertises... If you then tune the car, you will be able to squeeze more gains out of the mods.
ZZcamaro is offline   Reply With Quote
Old 03-18-2010, 06:04 PM   #5
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
I installed the K&N CAI myself. You remove the negative battery cable first and the computer will recalabrate. You will have to reset your clock and you may need to reindex your windows. Of course, if you tune, you'll see better gains.
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 03-18-2010, 06:19 PM   #6
Mac the Knife
Drives: 10 ss/rs 13 ram
+ 1,no codes or problems with mine also
Mac the Knife is offline   Reply With Quote
Old 03-18-2010, 10:07 PM   #7
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
ummm, i just installed a vararam intake last night and it runs good without a tune
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 03-18-2010, 10:27 PM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
You shouldn't need to take off any battery cables to install a CAI. The PCM will read the new airflow, if the CAI is built properly. Some of them are known to throw your LTFT's way out of whack, which would take a tune to bring them back inline.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Airaid V6 Intake Group BUY! JDP Motorsports V6 Bolt-Ons & Tunes 41 12-31-2009 01:44 PM
JDP Motorsports Airaid Intake Specials! PM for Coupon Code! JDP Motorsports V8 Bolt-Ons & Tunes 13 12-02-2009 11:44 AM
Stealth Performance--Airaid Cold Air Intake GROUP BUY!!--Great Deal Torchdvette V8 Bolt-Ons & Tunes 140 11-01-2009 06:18 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 07:37 PM
