04-27-2010, 08:02 AM | #1 |
Drives: 4 wheels Join Date: Mar 2009
high temp Clutch/brake fluid
I'm thinking about adding a seperate reservior for the clutch. Does anyone know of a higher temp fluid available? If not do I still use the same fluid from GM in both reservoirs?
04-27-2010, 09:32 AM | #2 |
Drives: 2SS w/ ZZ427 Package!! Join Date: Oct 2008
There are a lot of choices out there, I just went through this as well.
I decided to run the WilWood 570, it has higher ratings than the factory fluid, much higher actually, but it is not nearly as expensive as some of the others. you will see a lot of people say to use Motul 600RBF, which is also a great option, it is just too exspensive for my taste. Always happy to help, PM me if you have any questions. |
04-27-2010, 11:14 PM | #3 |
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
Motul RBF600, works very well. It is $15 per 500ml bottle. It will take aprox 3 bottles to replace all your fluid. Then just an ounce or two to flush your clutch reservoir after a track day. If you are at Bandimere tomorrow, I can go over the conversion with you. By the way, most motorcycle shops carry the Motul fluid.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
04-28-2010, 07:05 AM | #4 |
I think I'll try the WilWood 570, once I get the separate reservoir.
Similar Threads | ||||
Can't Decide - Auto or Manual | attymf | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 213 | 02-22-2022 07:48 PM |
High Wing Spoiler or Not? | RSm1thX | Cosmetics and Lighting Modification Discussions | 109 | 04-03-2013 05:36 PM |
What is the 4th gauge in a MN6 2SS? (not a tranny temp, like an auto) | MajikMD | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 7 | 07-18-2009 07:55 AM |
Mystery fluid | 96CAMaro | 4th Generation Camaros | 6 | 07-30-2008 06:03 AM |
