05-06-2010, 10:08 PM | #1 |
Drives: 2010 Join Date: Sep 2009
What vendors make aluminum and racing drive shafts for the SS?
Curious if anyone has done this and if they retained the 2 piece design or not.
05-06-2010, 10:13 PM | #2 |
Drives: 05 GTO Join Date: Jul 2009
We'll have one out soon. Were working on having one in a Camaro for the Power tour next month.
It's a one piece with a billet pinion yoke, the only way to go for performance driveshafts IMO. Thanks Chris |
05-07-2010, 12:05 PM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
will it be for the auto or man and a 1 or 2 piece
05-08-2010, 02:33 PM | #4 |
Drives: First 9 inch-12 bolt IRS Camaro Join Date: Jun 2009
We have a 1 piece and a 2 piece that we have been testing for a while ,it seems the camaro just like other irs cars of this day and time are not set up to use a 1 piece ,not only does a one piece have a lower critical speed it will be more prone to vibration.We have not given up on the one piece but it hasnt past our test yet.We will have a two piece ready shortly.
05-08-2010, 09:43 PM | #5 |
I was just going to ask on the one versus 2 piece.
I think this is the problem we are facing with rear driveline vibrations and the rubber donut. Next week I am pulling the stock unit to send out for a rebalance job. Hope it works but I rather use a nice lighter aluminum unit. PM direct if anyone has something that works and doesn't vibrate. |
05-09-2010, 12:07 AM | #6 |
We've had great success with the one piece driveshafts in the GTO. The GTO's are IRS cars and the one piece shafts work great in them.
Here are a couple threads on our GTO shafts, sorry if they are many pages long but they are full of excellent reviews. Take a look through these threads at the feedback, reviews and pics and you’ll see that everybody loves the one piece shafts. http://www.ls1gto.com/forums/showthread.php?t=285009 http://www.ls1gto.com/forums/showthread.php?t=307526 We don’t make a 2 piece driveshaft. I don’t like 2 piece shafts. They work great for OEM applications where drivetrain vibrations and chassis miss alignment issues require them but IMO they have no place in a high powered performance car. They are heavy, they have the middle bearing support that can fail at high speed and are an extra parasitic power loss point. There are no 2 piece shafts that are SFI approved that I know of, our one piece carbon fiber shafts are SFI approved and tested to hold 2800 ft lbs of torque and run 180 mph on the dyno with absolutely no vibrations. The Carbon Fiber shafts have a very high critical rpm speed, over 10,000 rpms! Our one piece shafts use billet pinion yokes and don’t use vibration prone adapters like some 1 piece and 2 piece shaft manufactures have used that gave aftermarket shafts a bad rap. I'll have one of our 3.75" carbon fiber driveshafts in a very high profile car on the power tour in a few weeks. We've had a couple of our prototype shafts in cars in Florida for about 6 months now and they work flawlessly. Once we get some feedback on how the carbon fiber shaft works on the power tour we'll get some pics and prices out. Thanks Chris |
05-09-2010, 10:45 AM | #7 | |
05-09-2010, 10:52 AM | #8 |
Hey g force
Are you saying a 1 piece carbonfiber drive shaft that will actually fit the 2010 camaro has a critical speed of 10,000rpm?
05-09-2010, 02:57 PM | #9 | |
It's more like 11,000 - 11500 rpm's. The big carbon fiber shafts can really turn the rpm's. Thanks Chris |
05-09-2010, 06:47 PM | #10 |
Good info so far. The only reason I have interest is because my 2 piece OEM unit is causing a vibration at high speeds. I think its the offset and the rubber donut.
I had this issue many years ago on another car with a 2 piece drive shaft. I later switched to an aluminum one and the problem was solved. I had the car up and all the stuff readjusted and still not much different than before. Its something with the design of this car. Some guys dont feel it and others do. it also depends on how fast your driving and I notice lots of 5th Gen guys are pampering their cars. If time permits this week I am going to pull my OEM and send it to the local shop to balance check it. Something has to be off. |
05-09-2010, 07:26 PM | #11 | |
05-12-2010, 06:03 PM | #12 |
when you get that carbon fiber driveshaft going, pm me and let me know. im still wanting one pretty bad.
Brixton Forged
CM10 Wheels IN STOCK!!! RF7 SOON!!!! Camaro/M3/M4 wheels in stock High Gloss Titanium |
05-12-2010, 06:13 PM | #13 |
05-25-2010, 06:55 PM | #14 |
Were getting close, here is our billet pinion yoke.
Fresh out of the machine shop |
Similar Threads | ||||
CAMARO WIKI | Tran | Wiki | 66 | 04-22-2024 11:41 AM |
MTI Racing 500ci Dominator Engine Assembly | MTI Racing | Forced Induction - V8 | 10 | 08-28-2009 04:05 PM |
MTI Racing 500ci Dominator Engine Assembly | MTI Racing | 4th Generation Camaros | 1 | 08-27-2009 11:00 AM |
MTI Racing 500ci Dominator Engine Assembly | MTI Racing | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 08-27-2009 10:59 AM |
