Old 05-20-2010, 06:49 PM   #1
Tim's.2010.Camaro.SS
Drives: 2010 Camaro SS
Camaro 2010 Issues
Camaro owners,
I purchased my 2010 camaro 2ss on March 18, 2010. The car had a little over 2000 miles, I love my vehicle, but less than two weeks after purchasing it I began to have clutch problems. I've owned 8 chevy vehicles and several sports cars that were manual. This Camaro made noises when depressing the clutch, is hard shifting into third, and is slipping in 2nd and 3rd.
On 4/5/10 I brought my car in for service. After inspecting my vehicle, I was told the the clutch was bad. They advised me that if the car had been abused, that the warranty wouldn't cover it. I was hardly worried about that, since I hadn't even done a whole shot with it yet.
4/6/10 Chevy drove the Camaro and advised me that there was no problem at all with the clutch. They also told me that this was the 1st manual 2010 Camaro that they had seen.
4/6/10 12:10pm I called GM customer support. I told them that the clutch needed to be opened up and inspected because I was certain there was a problem. She was able to get the dealer to open the clutch assembly, and found a bad clutch disc with a groove in it, and an uneven pressure plate with bad springs from the factory. No abuse was found and the vehicle was repaired under warranty.
4/9/10 I picked up the car, and the clutch felt perfect. All the issues were gone, and the clutch was firm grabbing at the low end of the pedal. It was smooth shifting into third, and the noise was gone.
4/12/10 The vehicle started to show the same issues as before, after driving the car only 150 miles, I called GM and advised them of the problem, and they told me to bring it in on 4/19/10
4/19/10 dropped the vehicle off, and was told later that there was air in the line. They performed a vacuum bleeding procedure.
4/20/10 Picked up my vehicle from the dealer and found two scratches. One on the drivers side front rim, and one by the drivers side door handle.
4/24/10 I called GM to advise them that the car had been scratched and it was shifting hard into third again, and now the clutch was grabbing at the extreme high end of the pedal making noises when it did.
4/26/10 I called the dealer and explained the issues.
4/27/10 I spoke with GM at 6:45pm in regards to the Camaro having more issues than when I first had it fixed. He told me that I had to bring it back to to the same dealer since they repaired it. He also sent my file to a district specialist for my area.
4/27/10 I called GM and asked if the entire clutch could be replaced since something keeps causing parts to fail and the repairs to it only last about a hundred miles or so. GM said if anything else goes wrong with it, that they'll try to get that done
5/4/10 dropped the car off at the dealer, and was advised that the vacuum bleeding that they performed on 4/20 had not gotten the air out of the system, and now the Throughout bearing actuator cylinder had to be replaced.
5/5/10 Picked up the car again and took it straight home about 4 miles. The car felt worse then ever. It was making a loud noise at low speeds when depressing the clutch, and was now slightly grinding going into third. It was now slipping in second as well.
5/5/10 I spoke with the district specialist and told her how bad the car was driving. I reminded her this was the third time the car had been in for the same problem.
5/6/10 I called a different Chevy dealer and asked them to take a look at the car. I drove about a mile on the highway. The car burst into smoke at 60mph. I pulled off on the median and called roadside assistance to have it towed to the dealer. THE CAR WAS ON THE SHOULDER IN A HUGE CLOUD OF SMOKE!!!!
5/6 The tow truck driver while hooking up the car tried to throw steal hooks under the car, and threw the hooks into the front valence of the car causing another big scratch. After service had taken a look at the car, they found that the line going to the trans cooler was not fastened from the dealer that worked on the car. I lost all of my trans fluid on the highway. When the tech pulled the plug, NO TRANS FLUID CAME OUT.
The dealer where the car was at now, told me that I had to go back to who fixed it because it was there fault. Before leaving I asked to speak with the tech that re-connected the trans line to ask if he thought any damage was done to the trans. He said he couldn't be sure without pulling it apart, but that it's a good bet that something in the trans was damaged.
5/6 12:07pm I called the tech that had last worked on my car about the trans line. His exact comment was THOSE LINES COME OFF ALL THE TIME, IT'S NO BIG DEAL!!
I called the district specialist from GM to explain what had just happened on the highway. She told me to bring the car back to the original dealer that messed up the car. I said no way after all that they have done to my Camaro that only had 3,000 miles. I also said that at this point the entire clutch should be replaced and possibly the trans depending on damage.
She called me later that afternoon to tell me that she had recieved approval to replace the entire clutch assemly and to inspect the trans if I brought it back to the original dealer that performed the work, so I told her that I would.
5/10 GM's district specialist called to tell me that the dealer didn"t think checking the trans was warranted and that there is nothing wrong with the clutch. A couple hours later GM called to tell me that the master cylinder was found to be bad and that they were going to replace that now. However they still weren't going to inspect the trans, or open up the clutch.
5/12 After 2 days of pleading with GM to have the trans and clutch inspected. They authorized the dealer to tear apart the trans to look for any damage.
5/14 The dealer told me that the car was driving like a dream, and it was ready for pick up. When I asked the tech what they had found, they told me that nothing was wrong and it didn't need to be inspected.
5/17 I had a long talk with corporate GM, and finally they forced the dealer to take a look at the clutch and trans.
5/18 The dealer called me to let me know that the flywheel in the clutch was now bad and needed to be replaced. Also fourth gear had teeth missing and needed to be replaced as well.
I'm sorry if this post is really jumbled, but there's alot of information.
Please keep in mind that I love the new Camaro. It's not even 2months old to me, and not even a year from the factory. I've had over 17 spinal surgeries and this was the one thing I wanted to do for myself after all of the surgeries. I spent all of my savings on this car, and now my dream car is turning into a nightmare!!!
Thank you for listening
Sincerly,
.AOLWebSuite .AOLPicturesFullSizeLink { height: 1px; width: 1px; overflow: hidden; } .AOLWebSuite a {color:blue; text-decoration: underline; cursor: pointer} .AOLWebSuite a.hsSig {cursor: default}
Tim's.2010.Camaro.SS is offline   Reply With Quote
Old 05-20-2010, 06:55 PM   #2
LS3 SS
Drives: 2010 Cyber Grey Camaro SS (LS3)
Wow..and im supposed to pick mine up in about 45 minutes. I have been reading everyone's issues with oil consumption, clutch issues, and other things and im starting to wonder is the enjoyment of the car itself, worth all of the issues that have been found??
LS3 SS is offline   Reply With Quote
Old 05-20-2010, 07:03 PM   #3
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
Wow... that dealer sucks. If it has any more problems, instead of asking them to fix it... I'd be asking for a new car.
Sterling is offline   Reply With Quote
Old 05-20-2010, 07:12 PM   #4
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
That's quite a story... I hope things work out for you. I usually don't buy a first model year car but I did this time. The only issue I have so far, is a noisy transmission.
Cam 427 is offline   Reply With Quote
Old 05-20-2010, 07:12 PM   #5
code3 ss
code3 ss's Avatar
Drives: SW,SS1 RS,GRND EFFCS,ORNG STRPS
WOW!
code3 ss is offline   Reply With Quote
Old 05-20-2010, 07:20 PM   #6
SpeedDemon21
Drives: 69' Z/28 Camaro Black on Red
Any car will have problems, specaily for the first year of a totaly new model. It just sound that the dealer techs were a bunch of idiots. That list could of been a whole lot shorter if they did every thing right the first time and took pride in it.
SpeedDemon21 is offline   Reply With Quote
Old 05-20-2010, 07:26 PM   #7
Rage
TRI-COUNTY CAMARO... FTW!
Rage's Avatar
Drives: 2010 Camaro 2SS M6 Cyber Grey
Really....I would have invoked, or at least threatened them with the Lemon Law.
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
Rage is offline   Reply With Quote
Old 05-20-2010, 07:28 PM   #8
Patfan1987
CGM is the Best! Thx GM
Patfan1987's Avatar
Drives: 2010 2LT RS Camaro, Auto + Sunroof
Wow sry to hear this!
Proud Owner of a CGM 2 LT/RS Auto Transmission w/Sunroof and Spare Tire
Patfan1987 is offline   Reply With Quote
Old 05-20-2010, 07:40 PM   #9
ron10
Drives: 2010 2SS IOM L99
dude,do you have any hair left?i hope i don't have trouble with mine.i don't know if i could be as patient as you.i would probably go postal.i sincerely hope they get you back on the road with no more problems.
Old 05-20-2010, 07:50 PM   #10
MrGazinya
MrGazinya's Avatar
Drives: Aggressive
No lemon law can be applied here
I feel for you dude, seriously
Black 2SS RS LS3 Inferno Int. '17 1LE replica 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Ideal performance upgraded clutch master cylinder:Tick performance upgraded slave cylinder/throwout bearing: Mantic 9000 twin disk clutch & light weight flywheel: Tuned by Doug Ring at ECS. 475RWHP/445RWTQ.Dynapack Dyno.
MrGazinya is offline   Reply With Quote
Old 05-20-2010, 07:58 PM   #11
Jamie Mac
NCM-WINR
Jamie Mac's Avatar
Drives: 2010 SS/RS IOM 2014 2LT Stingray
Here's another Milk.
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
Jamie Mac is offline   Reply With Quote
Old 05-20-2010, 08:16 PM   #12
detroitboy
Pinholic
detroitboy's Avatar
Drives: 11 Silverado, 08 Shelby GT500 Conv.
Lemon law in Michigan for sure....hope your state has the same requirements.
Almost had a 2SS/RS, IOM, orange accent interior, 6 speed manual, sunroof & polished wheels
ordered 01/19/07
3000 - 2/27/09
3400 - 3/27/09
3800 - 4/17/09 (built and lost in the vortex)
ship date ??????? (I gave up and got a GT500)
5/11/09 - order cancelled
5/27/09 - vehicle arrived at dealership for whoever bought it after me
detroitboy is offline   Reply With Quote
Old 05-20-2010, 08:28 PM   #13
IBM 2SS
Drives: 2010 IBM 2SS/RS
You wouldn't have this problem if you had an auto.
IBM 2SS is offline   Reply With Quote
Old 05-20-2010, 08:39 PM   #14
LS 1st gen
Kept the Faith.
LS 1st gen's Avatar
Drives: 2010 VR 2SS
Send a message via AIM to LS 1st gen
Lemon Law it!
SOLD 2010 Camaro # 13694 Victory Red 2SS manual | White rally Stripes | Polished Wheels | Rotofab CAI| MGW Shifter| Kooks LT's| Magnaflow X-pipe|FM 40 Delta Flows | Elite Tunnel Brace | "Ginger"
LS 1st gen is offline   Reply With Quote
Official SYNERGY GREEN Camaro Thread Tran Camaro Photos | Spyshots | Video | Media Gallery 4512 03-11-2026 10:01 AM
CAMARO WIKI Tran Wiki 67 11-27-2024 08:02 AM
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 36 04-02-2020 05:32 PM
