Old 06-08-2010, 09:45 PM   #1
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
Any hints on how to remove nuts from inside trunk lid?
I opened my trunk for the first time in months and heard something rattling around. I immediatly suspected a spoiler nut had come loose so I removed the rubber nut covers and found that not only 1 spoiler nut had some loose, there are 2 of them rattling around inside of the trunk lid. I can hear them moving when I raise the trunk lid up and down but I can't see them.
Obviously the car is still under warranty but I hate to take it in for something like this. I have no problem replacing the nuts but I don't know what size they are, but I hate the sound of the nuts rolling around inside of the trunk lid and I want them out.
Would you guys remove the trunk lid completely and try to get the nuts out yourself, or would you simply take it to the dealer and let them deal with it? Does anyone have a suggestion on how to get them out without removing the trunk lid?
Russ
OHIOSS is offline   Reply With Quote
Old 06-08-2010, 09:49 PM   #2
motorhead
Russ
I took mine in for this problem. A problem is a problem no matter how small it's their job to fix it. They had to remove my trunk lid to get them out of mine. If they scratch it they pay. If you scratch it you pay.
Old 06-08-2010, 10:09 PM   #3
2Fast4Mu
Nothing is True
2Fast4Mu's Avatar
Drives: Black 2014 2SS/RS
I did exactly the same. They said it was a common problem and they were happy to work on it. It only took a few minutes.
...Nothing is True, Everything is Permissible...
2Fast4Mu is offline   Reply With Quote
Old 06-08-2010, 10:10 PM   #4
Steve Dallas
Commits weekly crime
Steve Dallas's Avatar
Drives: 2017 Camaro 1LT
Most people haven't figured out how to get Shunt out of the trunk...
2017 Camaro 1LT - Blue Barchetta IV
I fire up the willing engine, responding with a roar. Tires spitting gravel I commit my weekly crime.
Steve Dallas is offline   Reply With Quote
Old 06-08-2010, 10:20 PM   #5
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Remove trunk lid cover and use a magnet on a stick to remove nut(s).
Old 06-08-2010, 10:26 PM   #6
CanadianCamaro
CanadianCamaro's Avatar
Drives: 2SS/RS IOM - A.K.A. DA ;)
Strong magnet and a polish rag. Remove the lid liner, locate the nuts, place the magnet on underside of lid surface with polish rag between the magnet and the painted surface, slowly pull the magnet along the surface to an openning. The nut should come along for the ride. I used a micro mag light flash light and a small inspection mirror to look down inside the trunk lid while doing this to see if I had picked up the nut.
CanadianCamaro is offline   Reply With Quote
Old 06-08-2010, 10:30 PM   #7
fireresq157
fireresq157's Avatar
Drives: 1997 SS & 2010 2SS/RS
Service departments are starving for work any work if you want to help your local economy take it in that's what they are there for.
fireresq157 is offline   Reply With Quote
Old 06-08-2010, 11:12 PM   #8
gotroost
gotroost's Avatar
Drives: 2021 Crush ZL1 1LE
If you have enough room to fish it in, a pick up tool (Craftsman PN 00941322000) with a magnetic bit from a socket holder (or strong magnet) might grab it. I've use this setup several time to retrieve bolts, washers, etc.
gotroost is offline   Reply With Quote
Old 06-08-2010, 11:20 PM   #9
TahoeCamaro
TahoeCamaro's Avatar
Drives: '10 Camaro SS/RS VR, '11 Tahoe LTZ
The name of this thread...
TahoeCamaro is offline   Reply With Quote
Old 06-08-2010, 11:35 PM   #10
bluch
OH CANADA!
bluch's Avatar
Drives: 2011 RAM 1500 LARAMIE
remove the carpet covering. i did that, and when i drove to the store to buy a telescoping magnet and back home, they had both fallen out and into the trunk
Had to trade in the Camaro for a truck :(, but hopefully I can join the Camaro family again one day
bluch is offline   Reply With Quote
Old 06-09-2010, 12:26 AM   #11
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
There's actually a service bulletin about this so it's covered under warranty. Take it to your dealer; they should have sent you the recall on it but obviously didn't.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 06-09-2010, 12:32 AM   #12
cterry
So Cal Race Team
cterry's Avatar
Drives: 2010 Carmaro SS/RS
cterry is offline   Reply With Quote
Old 06-09-2010, 03:14 AM   #13
lwlkr92
lwlkr92's Avatar
Drives: 2010 IOM Camaro 2SS/RS 6M
Open trunk first, remove affected organs, call 911. I think we got a bleeder here. Sorry, but I couldn't resist. Anyone know if this only a problem on early runs or not?
lwlkr92 is offline   Reply With Quote
Old 06-09-2010, 06:09 AM   #14
2010IBMSS
2010IBMSS's Avatar
Drives: 2010 camaro SS RS
so, would you all recommend some thread locker on the nuts as a preventive measure? not a lot of thread locker, just enough so they won't come loose?
2010IBMSS is offline   Reply With Quote
How Many Camaro5 members does it take to change tighten spoiler nuts ffrcobra_65 5th Gen Camaro SS LS LT General Discussions 59 02-17-2010 06:31 AM
Can an RS/SS Tire/Wheel Fit Inside the Trunk? HotRodPilot Wheels and Tires Talk Sponsored by The Tire Rack 10 01-11-2010 04:08 AM
Trunk Lid Rattle Slake Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 10-18-2009 02:07 PM
New Leather Accent To Console Lid (Pictures Inside) dsvcustoms Cosmetics and Lighting Modification Discussions 10 10-03-2009 07:47 PM
Spoil Ur Nuts...better check! Matster Canada 25 09-07-2009 01:10 PM
