Old 06-09-2010, 03:28 PM   #1
fastfaster
Drives: xxxxxxxxxxxxxx
who sells aftermarket rear ends / diff (or diff parts) for the 2010 camaro
who sells aftermarket rear ends/ diff (or diff parts) for the 2010 camaro
fastfaster is offline   Reply With Quote
Old 06-09-2010, 03:48 PM   #2
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
I know Jannetty Racing does upgrades on them but I'm pretty sure you need a core or send original.
Might check with them anyway...
Old 06-09-2010, 05:18 PM   #3
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
What are you looking for? A housing? Complete set-up? How much are you planning to abuse it, i.e. how strong are you looking for?
Apex Paul is offline   Reply With Quote
Old 06-09-2010, 05:50 PM   #4
Camaro21
Drives: SOLD - 2013 M6 ZL1
Andy at ADM Performance is doing a Swap for me. I am getting 3.73 gears and he is just exchanging the rear end assembly out. It will take him about an hour to complete.
Camaro21 is offline   Reply With Quote
Old 06-10-2010, 11:15 AM   #5
fastfaster
im looking for a stronger complete pumpkin that can be bolted to my axles. if that cant be found, i'd like to buy stonger internals to upgrade mine.
stronger than stock would be nice
Old 06-10-2010, 12:10 PM   #6
Melson
Melson's Avatar
Drives: Wild Cherry
Andy at ADM swapped mine and it took about 45 mins or so........
2010 RJT 2SS/RS L99 CAMARO
ARH 1 7/8" LT HEADERS W/ HF CATS
MAGNAFLOW 3" COMP EXHAUST
ADM PERFORMANCE CAI
ADM PERFORMANCE CUSTOM TUNE
ADM PERFORMANCE PORTED THROTTLE BODY
ADM PERFORMANCE TRANS COOLER
3.45 GEARS
BMR TRAILING ARMS
Melson is offline   Reply With Quote
Old 06-16-2010, 07:41 PM   #7
GFORCE1320
Drives: 05 GTO
Our new 35 spline spools are now ready
Now we just need to make some matching 35 spline stubs to go along with our current axle line up to work with the spools.
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
Old 06-16-2010, 10:14 PM   #8
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
9 inch IRS in production
We will have the 9 inch IRS ready in about 30 days,buy the best parts once and never look back
Hendrix-Engineering is offline   Reply With Quote
Old 06-17-2010, 06:16 AM   #9
fastfaster
aaarrrgggg, i need it now!!!!!!!!!!!!!
Old 06-17-2010, 06:44 AM   #10
BlackCamaroSS
Old school SS, junior
BlackCamaroSS's Avatar
Drives: Many; all Chevrolet
For those who had ADM do the swap, would you mind telling us an approximate price, and is 3.73:1 the steepest they have? Thanks.
BlackCamaroSS is offline   Reply With Quote
Old 06-17-2010, 06:46 AM   #11
68 Z/28
Father Time
68 Z/28's Avatar
Drives: 1967 Malibu / 2002 Caddy DTS
Send a message via Yahoo to 68 Z/28
Richmond Gears
She's been sold ( Goodies List Updated )http://www.camaro5.com/forums/showthread.php?t=86262
68 Z/28 is offline   Reply With Quote
Old 06-19-2010, 09:53 AM   #12
BLWN SS
BLWN SS's Avatar
Drives: Orange SS/RS W/ White Stripes
Is this a direct bolt in replacement? What ratios available? Pricing?
I just wasted my posi and am looking to upgrade the whole dam thing once!
BLWN SS is offline   Reply With Quote
Old 06-23-2010, 08:52 AM   #13
Hendrix-Engineering
Yes this is a direct bolt in,you will provide your on posi and gear .The gear chioces for a 9 inch are almost unlimited ,from 2.30s-6.40s!! and starting at $140 Ill have a thread started and some pictures real soon There will be a limited number so if you would like to get in on the first run you need to give me a call 980-521-0722 thanks. This kit will come with the bolt in nine inch housing,heavy duty drive shaft with 1350 u joints,our huge axles with custom cvs,stongest avalible,and 300 m inners and outers.A complete solution,do it once and forget about it!
Old 06-24-2010, 05:59 PM   #14
GFORCE1320
Drives: 05 GTO
We have the bolt in 12 bolt and 9 inch IRS in work. The MOD-12 IRS rear will be available in both a 12 bolt or 9 inch with our stubs, axles and driveshaft.
We have one of the 12 bolts (Mod-12) and our Outlaw axles in a 1,000hp car that will be in Hot Rod magazine this coming up issue. Dont think this issue will cover the rear, mainly the engine build. It's a multipart article.
We've been keeping everything pretty hush hush until we get everything geared up and into production but pricing, availability and photo's should be out soon.
Thanks
Chris
Im sure this has been asked before.. But forgive my innocence :) gmag21 Suspension / Brakes / Chassis 23 02-21-2010 10:29 PM
