07-10-2010, 05:33 AM | #1 |
Drives: 2011 2SS m6 Join Date: Apr 2010
Adam's question
Ok so I have used Zaino for years, but after spending some time on these boards, I've decided that Adams is the way to go. I have a 2011 IOM 2ss with white stripes. This is my plans, I will wash, and clay first using detail spray as the clay lube. Then by hand I will use swirl and haze, followed by revive. Finish it off with buttery wax. In between washes I will use detail spray and brilliant spray glaze. So this is my question should I perform all of these steps on the stripes as well, I was thinking of just using detail spray and the spray glaze on stripes, but I'm not sure. Also if any of my steps are wrong please tell me, I'm a pure novice when it comes to adams products, but looking forward to using them...
7/7/10 Status: Delivered
07-10-2010, 09:46 AM | #2 |
Drives: The shiny ones. Join Date: Mar 2010
For the stripes you could go that route, but the better solution is our Clear Polish.
07-10-2010, 11:30 AM | #3 |
You probably won't notice any difference using the SHR by hand. Do you have a PC?
[B]
07-10-2010, 12:26 PM | #4 |
12.23s@113mph
Drives: 2SS/RS, A6, just a few bolt ons Join Date: Jul 2009
DO NOT use SHR on the stripes!!!
and like dylan said, clear polish is all the stripes need.
RIP Cammie 7/15/2009 - 4/1/2011 |
07-10-2010, 01:12 PM | #5 |
Nope, I'm afraid of the pc. Since I have never used one I don't want to start on this car. I will eventually get one and practice on other people's cars first. Right now the finish looks pretty good there are a few spots with some light swirl and webs, I'm hoping the SHR by hand will get those out.
07-11-2010, 09:52 PM | #6 |
Drives: 2011 Camaro Silver Ice Join Date: Mar 2009
I'm thinking of getting the factory grey stripes and was wondering about maintenance as well, should the stripes be clayed with the rest of the car?
07-11-2010, 10:01 PM | #7 |
Detailing Connoisseur
Drives: 2010 Rally Yellow 2LT RS Join Date: Nov 2009
I have CGM stripes on my rally yellow. I have clayed them before without issues. I wax them regularly. If you don't get matte stripes you can wax them without any issues.
07-11-2010, 10:41 PM | #8 |
07-12-2010, 12:57 PM | #9 | |
Drives: 2010 Camaro 2SS Join Date: Jun 2009
07-12-2010, 01:46 PM | #10 | |
try it on the camaro.
07-12-2010, 02:02 PM | #11 |
Really nothing to be afraid of with a PC - check these videos out for confirmation:
http://www.adamsforums.com/forums/showthread.php?t=4034 If you do decide to go by hand, just set reasonable expectations. You can REDUCE swirls and scratches by hand, but you won't REMOVE them. If you want a quick easy way to go then skip SHR and just do Clay>Revive>Buttery Wax. SHR tends to be a bit of work by hand, but it will get you better results. Like anything detailing is a practice that you get out what you put in. |
07-12-2010, 02:02 PM | #12 | |
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man Join Date: May 2009
07-12-2010, 06:44 PM | #13 |
How do you know if you need to use the swirl and haze remover or just the fine machine polish. I use waterless wash and I have some scratches from not using a duster before the wash. The scratches are in a straight line and not in swirls.
07-12-2010, 06:53 PM | #14 | |
Do a test section with the white pad and FMP... if it fixes it you have your answer, if it doesn't either do a 2nd pass or step up to Swirl & Haze Remover. Always start with the least aggressive approach first, inspect, then proceed. |
Similar Threads | ||||
Waterless wash vs. Full wash using adams kit | JProberts | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 14 | 05-21-2010 01:21 PM |
zaino vs adam's | youngkim | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 251 | 05-16-2010 01:07 PM |
Adams switch over | PB3 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 4 | 05-04-2010 09:26 AM |
Custom wheel offset question ... | Bowtie Junkman | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 04-23-2010 05:16 PM |
Question Involving 4.10 gears & Bushings | Deric884 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 02-13-2010 06:53 AM |
