Old 09-25-2019, 01:04 PM   #1
teeroy97
teeroy97's Avatar
Drives: 2011 Camaro 2TTSS
Suspension Mods After Twin Turbo Install
I have an all stock 2011 SS LS3 with AGP 54/57 twin turbos on it, with upgraded fuel system.
I'm producing 619 whp on 8lb of boost. I'm about to do a clutch and turn the turbo up.
What suspension mods should I be looking at doing so I don't start breaking sh*t?
teeroy97 is offline   Reply With Quote
Old 09-25-2019, 01:48 PM   #2
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
Toe and trailing arms with maybe some solid rear cradle bushings that should help wheel hop.
_Onyx_Wolf_ is offline   Reply With Quote
Old 09-25-2019, 01:49 PM   #3
Omega
Drives: G8
Poly all the rear bushings/replace with BMR. You want to avoid wheel hop or you'll be buying axles and diffs.
Sent from my Pixel XL using Tapatalk
Omega is offline   Reply With Quote
Old 09-25-2019, 02:41 PM   #4
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Toe rods, trailing arms, differential bushings, cradle mount bushings, UCA bushing, LCA bushing, transmission mount < in that order.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
suspension modificiations, suspension mods, turbo
