08-19-2023, 07:11 AM | #1 |
Drives: 2016 Chevrolet Camaro SS Join Date: Feb 2023
Flashing CEL at WOT
Hello,
As the title says I’m getting a flashing check engine light at wide open throttle on my 2016 SS. I’ll be doing some pulls and on rare occasions this happens. I would say it happens every 2 months or so. Not often at all. Upon using my scanner I get the code p0300 multiple cylinder misfire. I would also like to mention that when I’m at WOT with the flashing CEL I’m experiencing no loss of power, no vibrations, no stalling or jerking, no backfires, and no stabilitrack errors or whatsoever. Car is still running completely fine. Once the CEL stops flashing I can go right back to WOT. Doesn’t usually happen again. I’ve brought this issue up to my shop before (TPS motorsports in San Jose, CA) and they replaced all my spark plugs and coil packs. My mods are a complete LT4 engine swap(bought brand new 2022, 20k miles on it now), tune, front and rear Bmr sway bars, rims and tires. I know there aren’t many LT4 swapped SS’s out there but has anyone in general ran into this sort of issue? Was hoping for some input before I call my shop who did the engine swap and maybe bring her back in. Thank you |
08-19-2023, 10:49 AM | #2 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
i think i used teckron fuel injector cleaner at double like the dose and it took card of it in a tank
08-19-2023, 10:53 AM | #3 |
Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Travis Lambert did a LT4 swap in his SS several years ago. Don’t know if he is still a member on this forum but you might be able to send him a PM and ask him questions that you have.
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
Tags |
check engine light flashing, lt4, misfire |
