06-17-2010, 11:31 PM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Nov 2009
Developed a slight delay between gears on my SS
So I've noticed lately that there is a delay that has developed in power delivery when shifting gears at WOT. For example... I'll be in second and pin the throttle, then quickly shift up to third (lifting slightly to shift) then immediately back on the throttle. I'll have the clutch fully engaged, and my 'go fast' foot to the floor, and there is what seems like a fully .5 - .75 second delay before the power is kicking back in.... a lot like a someone performing a slow shift.
This has started happening shortly after removing my rear cats, so perhaps that's the culprit. Has anyone else experienced this? Maybe I just need a tune? I've been driving high performance manual tranny cars for years now, so I know it's not my technique. I'll be installing some shorties soon (if they ever show up ) so after that I'll perhaps take a trip to the dyno to read my A/F and see what's going on.
2010 Camaro 2SS/RS -6M
397whp/393 ft/lbs |
06-18-2010, 05:23 AM | #2 |
Sounds like Torque Management kicking in. It closes the throttle blade if it thinks the car is going to put to much torque on the drivetrain.
06-18-2010, 09:08 AM | #3 |
hmmmmm
Drives: 2010 IOM in-n-out 2SS Join Date: Oct 2008
yup,
turn traction control off and that goes away, it thinks your going to chirp 3rd which you will if you remove just click the button. try it out , u will feel the difference
"Responsibility is a Heavy Responsibilty" (Cheech)
06-18-2010, 11:16 AM | #4 | |
Banned
Drives: 2003 Cobra Convertible Join Date: Feb 2009
tons of LS1 camaro's have had this issue, especially the LS2 GTO's. even the cobra's have it. sucks, but that's the way they tune them. You'd have to get a tune to remove it. |
06-18-2010, 12:41 PM | #5 |
It's happening a lot with traction control off too... doesn't seem to make a difference. I had that same thought too when it happened the first time.
397whp/393 ft/lbs |
06-18-2010, 12:44 PM | #6 |
Dang computer nanny!!! Drives me nuts!
397whp/393 ft/lbs |
06-18-2010, 01:27 PM | #7 |
Drives: 2008 Chevrolet Silverado Join Date: May 2010
No Torque Manangement on the LS3
06-18-2010, 01:50 PM | #8 |
Booooosted.
Actually, yes they do. It's just way worse in the auto.
06-18-2010, 10:00 PM | #9 |
You are correct PQ. Not sure what I was thinking.
Similar Threads | ||||
Drag Test: 2010 Camaro SS | Nine Ball | 5th Gen Camaro SS LS LT General Discussions | 129 | 11-10-2010 06:28 PM |
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios | tbyrne | Transmission / Driveline | 9 | 01-11-2010 10:36 AM |
SS chirp gears? | CamaroEnergy4Life | 5th Gen Camaro SS LS LT General Discussions | 46 | 03-08-2009 07:42 PM |
Camaro LS / LT / RS / SS specs and options! | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 119 | 09-02-2008 09:46 PM |
