Old 11-23-2011, 01:24 PM   #1
scrubby43
scrubby43's Avatar
Drives: 2010 camaro 2lt RS
ported intake, heads and headers
Ok , i wanted to let everyone know about a project I started with my friends at RDZmotorsports. I've been thinking about how to get more power out of our engine without going FI route. I recalled reading about another member who worked on porting and polishing a set of heads and intake, but never finished by putting the heads and intake on the car. I decided this was the next best thing to FI. So attached are pics of the project. The car was put back together yesterday a trial run was made and datalogged. The log was sent to trifecta for analysis. Here is vince's reply.
"The log you sent was very interesting.
Under full throttle, normally these things show a bunch of knock retard, always. This one showed very little – it was able to run an amazing amount of timing. This should translate into some decent power gains. Fuel looked a little lean, and the trims were off slightly but it looked pretty good."
Tuesday the car will be put on a dyno and some fine tuning will be done with Vince at Trifecta. Ill let you know the results then.
2010 2LT RS Cyber Gray Metallic, White ralley stripes, JBA Shortie headers, SOLO perf HFC & Res. Magnaflow cat back, SS Brakes, Eibach Sways & Springs, Trifecta tune, VMAX throttle body & Catch Can, Custom ported intake, heads, Black ICE-olator, VARARAM.
scrubby43 is offline   Reply With Quote
Old 11-23-2011, 01:31 PM   #2
bcperry
Engineer in Training
bcperry's Avatar
Drives: IBM 2010 Camaro LS
looks VERY promising! Also looks like it'll cost a fortune for the rest of us. LOL Keep us posted with the numbers!
K&N Aircharger CAI, BBK LT's, VMAX black ICE, Trifecta tuned
bcperry is offline   Reply With Quote
Old 11-23-2011, 01:34 PM   #3
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
All right!! That's what I want to see!!
mhog is offline   Reply With Quote
Old 11-23-2011, 01:38 PM   #4
mhog
mhog's Avatar
What does the butt dyno tell you?
Old 11-23-2011, 01:40 PM   #5
Willt1984
Bowtie 'til I Die!
Willt1984's Avatar
Drives: 2011 Camaro CGM LS M6
Send a message via Yahoo to Willt1984
Subscribed!
Willt1984 is offline   Reply With Quote
Old 11-23-2011, 01:43 PM   #6
bmorecam
What was done exactly and how was it ported? I only see the gasket matched head inlet and outlet of intake manifold.
and same here with KR. I am only seeing around 5 max pass 4k rpm to redline on wot and this is only with the insulator and ported intake manifold. The AFR also went rich after the stg3 porting to 11's.
I would love to see the result
Old 11-23-2011, 01:51 PM   #7
scrubby43
scrubby43's Avatar
Have not driven the car yet. I'll let you know once I get the car back.
The intake was ported to match the gasket as was the head intake ports, the inlets were also machined to clean up flash and rough casting from the manufacturing of the heads and intake. The same applies to the exhaust ports, they were opened to match the headers ports.
Old 11-23-2011, 01:54 PM   #8
mhog
mhog's Avatar
Any valve work?
Old 11-23-2011, 02:02 PM   #9
scrubby43
scrubby43's Avatar
Any valve work?
No valve work just opening up the air inlets and exhausts to allow for increase in airflow. we are hoping by opening all systems up there will be a much more significant horsepower increase. The signs are there that something positive is going on, we need to work on the air/fuel and then we will see on the dyno.
Old 11-23-2011, 02:03 PM   #10
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
looks good...
hapisok is offline   Reply With Quote
Old 11-23-2011, 02:04 PM   #11
bmorecam
Originally Posted by mhog View Post
Any valve work?
That was my next question. Valve seats, bowls? any of those has been reworked? I think either way you should see a healthy gain
Old 11-23-2011, 02:05 PM   #12
hapisok
hapisok's Avatar
did you have it flow tested, before/after?
Old 11-23-2011, 02:11 PM   #13
scrubby43
scrubby43's Avatar
No flow testing. I followed what one of the other members did but never finished. I recall him doing some flow testing but do not recall the numbers.
Old 11-23-2011, 02:20 PM   #14
scrubby43
scrubby43's Avatar
If anyone wants to see more pics there are a lot more on RDZmotorsports facebook page.
Going to sell the camaro, ported heads are going to sell. bmwdon Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 61 03-10-2012 10:42 AM
Dyno numbers with New Era VVT cam and ported heads mike@newera Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 03-06-2010 12:48 PM
